I have read the old posts and searched and searched,but I am still unclear on several points regarding the conversion to 4runner calipers.
I have a stock suspension 85 FJ60. Drum brakes in the rear. Stock wheels.
I just bought 95 4runner disk calipers: S13WB (the bigger V6 ones?)
31.99 from O'Reilly's in stock. Everything but the pads.
I do not plan on replacing the master cylinder. I was hoping to just bolt these calipers on with some new ceramic pads, bleed them at the caliper, replace rear drum shoes and hardware, adjust rear drums and drive.
Has anyone done this on stock fj60, stock wheels, 95 4runner calipers?
Do I need to get longer hard lines at the caliper? Do I need to grind the caliper when using the stock rims? How much of the backing plate/dust shield needs to go? I ask, because I don't have a grinder or cut off wheel and I am wondering if I can get away with using a file or other less industrious method.
Thanks
Thanks
