Wanted Front and Rear Propeller Shaft for 1963 45LPB
MadMace
San Antonio
I am in need of a front and rear propeller shaft for a 1963 FJ45. The Chassis and Body Manual has these length at 525mm (20.67in) and 160mm (45.67in) respectively for the shafts.
I would like to do a direct pick up if possible. My son and I are taking a LONG road trip to pick up the 63 45LPB and I am hoping to pick these up along the way. We are traveling to Phoenix along the I-10 from San Antonio. Then up to Las Vegas. Las Vegas to Redding, CA. Will be stopping in and visiting with @kevos37 in Sutter. Sutter to Reno. Reno to Salt Lake. Salt Lake to Ouray, CO. Ouray to ABQ. ABQ to Lubbock then Lubbock back to SA. All this will be documented in a new thread starting next Saturday when we hit the road.
@kevos37, @whitey45, @pardion, @Tank5, @hyhpe --one of you I hope has one or both. Please let me know what you got.
Muchas Gracias!!
I prob have a rear but not on your route. I might be able to eventually get it to sante fe but not for a while
I may have these…and with the factory boot over the slipyoke still intact.
Dean I think I asked in another post about your rear diff but make sure you get a shaft that‘s for a centered rear diff if you have one (early ‘63‘s do, don’t know about later ‘63’s), they are longer.
Thanks Paul. I have learned so much from your thread. You had one post where you mentioned your rear diff being centered and that it changed to being off center to the right side on later ‘63s. I went right to the garage and checked and mine is off-center to the right. Our ‘63 has more in common with ‘64s than it does ‘63s.
