TOYOTADRUNK said:... new toyota air filter,
Jarrod,
Check the big hose that goes between the AF canister and the intake. You're looking for cracks... usually underneath and in the section that is shaped like a bellows.
-B-
Beowulf said:Rick,
I did a few searches over the weekend and I believe the search function has developed some new problem. I located specific posts so I knew exactly what words were in the post; then did a search. If the author was cruiserdan the search would NOT find the post.
I suspect a database re-index is needed.
-B-
TOYOTADRUNK said:hopefully with the FSM and some new parts and a little help from you guys I will solve my problem.
reffug said:Woody just kicked off a database re-index and that should cure the problem with the search function.
