sodajerk said:I have a 1997 lx 450 with lockers. My question is if nothing is lock should I be able to lift any one tire and spin it by hand or with the engine?
Thanks,
Russell
sodajerk said:I have a 1997 lx 450 with lockers. My question is if nothing is lock should I be able to lift any one tire and spin it by hand or with the engine? Thanks,Russell
RavenTai said:Never put the truck in gear when on jack/stands, the truck will try to come off of them unless you have all 4 tires off the ground or have removed driveshaft to any tires on the ground
RavenTai said:The Aussie locker instructions were probably written for the rear axle of a 2 wd or standard four wheel drive vehicle where drive to the front wheels can be disengaged.
I cannot imagine they would ask you to do that on an all wheel drive vehicle, but as you said without the VC you are much less likely to get into trouble, I still would have put all four wheels in the air or skipped the test altogether.
