- Thread starter
- #21
Let this be the first of many new SpressoFab offerings.![]()
Thank you SR.GRINGO! Your's are in the hands of USPS now
I can go take a look at Rusty's 100 to verify...but my FRBv2 is just slightly taller therefore better concerning the potential bumper interference compared to the OEM tie down bracket that is already mounted in the same location.
So if someone wants to know just take a look at your current tow point with a 7/8" bow/D shackle attached with string or winch line to see what angle causes interference. And no I'm NOT referring to the goofy "J" tie down hook on the passenger side (all you guys removed that POS right??!!)...but rather the tie down anchor on the driver's side...
Dan
Just sent money for two, thanks Spressomon!
good, but hopefully folks don't use tiedowns for serious recoveries, right?
SR.GRINGO said:Let this be the first of many new SpressoFab offerings.![]()
Do these interfere with skid plates at all?
Quick question: Does anyone else's washer not sit flush against the bracket when the bolt is all the way in?
I was just looking at mine (installing tomorrow) and washer sits slightly on the parts that starts to turn 90* and causes it to just sit slightly at an angle (sits up about 1mm). I just plan to take the washer and put it on a bench grinder to get a small bevel so it sits flush, just seeing if anyone else's is like this.
There is a slight interference as you noticed; however once torqued the washer will conform to the radius of the FRBv2. Its the slight compromise of trying to get as much strength packaged into a 'one size fits all' product.
IIRC you pulled me out of a creek bed outside Austin using one of the factory tie downs.More than you'd probably know.
Rant over.
IIRC you pulled me out of a creek bed outside Austin using one of the factory tie downs.![]()
Ah, thats what i figured.
One more thing:
What would be the preference for the orientation of the bracket with the vertical portion to the outside, or inside of the vehicle. My guess would be towards the outside as it would distribute the force better.
I picked up 2 brackets. Since I have a trailer hitch on the back would it be wise to put both up front? It says that working load limit is exceeded pulling from 1 for a normal hundy. thoughts?
PS: I have stock bumpers
