2001LC
Looking at 2000 LX with high millage. Noted a few areas of concern that may just need adjusting or could be clues to something very bad. Trying to understand what caused camber to become so negative. The three items below may be clues of hard impact from aggressive wheeling OR Unrelated and possible just hit a very bad pot-hole on PS front wheel. Saw sign that at least one wheel is bent on inner side of rim.
What other clues should I look for?
What parts may I need?
Could frame be bent, how to tell?
This last picture, is of a piece of cardboard across front to back door seam. Front door out about 1/8 inch from being flush with back door.
- PS wheel had a great deal of negative camber (bottom of wheel out, riding on inside of tire). It's apparently burning through front tires. DS has some positive camber, but not as noticeable. Front tires appear as if they've been switched recently, as wear pattern is wrong.
- PS leading edge of running board, bent up near front end.
- PS front lower half main body of door out ~1/8" (not closing tightly) from alignment with back door. Upper half of front door (window frame center post) flush with back door.
