?? for OEM locker owners (1 Viewer)
Hey, is the little tube that sticks out the the wiring harness the breather? I didn't look at the other end. I retrofit all the OEM harnesses and I noticed a couple of these tubes that went nowhere.
If so what did you use to connect it to the barb on the actuator? What is OEM?
It is a vent tube.
Connect it to the actuator. The opposite end terminates up in the harness.
CDan, did I thank you enough for the info? The connector pins, parts, etc.?Putting up with my dithering in regards to the harness? The real-time phone support? Made the conversion and wiring easy. Thank you.
No problem.
