Curran said:
Neglecting the body lift, your overall suspension travel will be the roughly the same for both the five and six-inch lift. Up travel will be limited by the bump stops and down travel will be limited by the length of the shocks. Since both kits use the same bump stops and shocks, I think it is pretty even. The difference is the starting point.
Couple things (I went from the Js to the six inch spring recently)
1. I wouldnt neccesarily look at the six inch springs as a "kit". If your shocks are limiting get some bilstiens under there that are longer... i am in the process of mounting my shocks differently to get more drop (there is defenitly more to be had). Main concerns fabbing up something simple up front for the ABS wires, and something to allow the E-brake cable in the rear to drop more... right now my cable has the last brace removed.
2. I would like to think my 80 is "light" compared to other 80s. no long range tank. tubed rear bumper... trimmed the ARB up front..no rear seats. no drawere systems. In regauds to weight i kept my Sway bars in the rear but fabbed up some cool spacers and it seems to let me flex all i want. I need some stability because i am dont have much weight so it feels like my rig is WAY up there.....
3. I have tried a 2 inch spacer up front and it is great at times for breaking over and head on obstacles but seems pretty tall when i get on off camber stuff. love the up travel on it though so its on it now.
4. I felt to really get ALL the flex i wanted and still have the drivability i wanted that i need something other than the slee fron control arms so i went custom. the are a little longer and allow more flex in "theory". will get lots of product testing on these in the near future.
SO why go 6 inch springs .......
I dont think you should do it JUST for flex cause i LOVED my J's with 35's really an amazing set up that lets most guys do everything they will ever want to do(think of all the 80s your seeing on the con and in moab, most on that set up)think of . I cant count the number of times that saw my 80 and the first thing they always said was "look at the flex" and mention the stability....
I think this is the funnest part of wheeling. have fun with it...
Oh ya.. dont just dithc your BUmp stops... you will want them to stop your rig before the shocks or body do.. just place them in the right place.
Go longer shocks... but you need diffent mounts so you can get more up and down travel ..
GOOD LUCK..
