BullElk
My air bags have a small leak. Would flat tire foam be a good option?
Thanks
Thanks
No. Airbags go off by a sudden (explosive) increase in pressure. Tires leak down and the foam plugs the hole.
I believe he's talking about a different kind of airbag...
And yes I have heard of people using fix a flat in airbags with mixed results. If they're already leaking its worth a try.
IMO they're gimmicky and dangerous, and if you need them, then your truck isn't set up correctly for how you're using it.
Prob wont be reliable or worth the effort to use fix-a-flat. Air lift bags are relatively cheap, better off getting some replacement bags if they are available separately; ( where you dont have to buy the lines and hardware etc). I might inspect the line routing to know why the bag failed- these can be pretty reliable if installed correctly.My air bags have a small leak. Would flat tire foam be a good option?
Thanks
Flat tire FOAM? What product is this?
Why not simply replace the part? Full airbag kits are less than $300, so I'd imagine just one replacement bag would be under $100.
I know nothing about them other than thery are red. Haa. I just inflated them and it raised the rear up about three inches and then I could hear air escaping. Guess I need to look for a hole, etc.
