Another member here thot that the hardcore section be the forum for best addressing my questions, so here it is.....
I am installing power steering into my 87 Samurai. Due to the complexity of also having a vw TD engine and the corresponding 26" rad to cool it, I need a powersteering box that has the pitman arm pointing forward, and it needs to mount to the outside of the frame rail.
I know others have used an FJ box for their samurai builds........ I already have a Toy IFS box and it will not work for the rad fitment issue.
Anyway, can you please tell me what advantages / disadvantages there are between the fj80 and the fj60 or 62 boxes?
I understand that they both have the pitman arm pointing forward, that the mounting bolt patternsare different, and that the splines are the same between the two. I have also read that the sector shaft is larger in the 80 box. Not sure if that really matters for my zuk with 33" tires.
I will have to plate, drill and sleeve the frame holes for either box.
If either box is physically smaller, as in shorter and having a smaller diameter of the housing, that interests me, as a smaller size will help me with the fitting of the 26" vw rad that will extend over both frame rails.
Thanks for your thoughts.
S
S
