Walking Eagle said:I don't think you are comparing apples to apples since you're not letting the other shocks fully extend - that was the real question I was after 1st.
ok. So are the bumpstops added to not over compress the springs or the shocks? Since I don't expect you to know what OME was thinking, how about on your 4 and 6" set-ups? I can think of 3 reasons for lowering bump stops.
1. Longer springs that would over compress.
2. Longer shocks that would bottom out.
3. Larger tires that you want to keep from rubbing.
Either you ended the post early, or you're indicating a piece of anatomy.
I'd guess that OME, recomending L's and J's together with said bump stop spacers, is properly accounting for what needs to be accounted for.
That's a clumpsy way of saying I tend to believe that OME knows their stuff better than most and would have more faith in what they say than in most mainstream US suspension manufactures in the US. I'd venture to guess they suggest lowering the bumpstops due to a limit in the shocks, not on the springs. But that's only a guess.
frankies off road said:That would be nice , i could use another 80 to wheel and test you mind a few dents will ya![]()
sleeoffroad said:Not sure I am following. I was concered about up travel and compression. Not sure I understand the not letting the other shocks fully extend.
sleeoffroad said:As I mentioned we do it to stop the shock from over compressing. As I also mentioned I think there are other ways to custom tune the bumstop size based on tire clearance and shock lengths. However the 2" we supply is a generic one for people that do not take the time to fine tune. That way we know that they will not have issues.
sleeoffroad said:The assumption is that the OME springs on an 80 are the optimized length and reaches full compression on the truck. So making that longer, we would have to add bump stops to make sure we do not over compress the springs.
