Good day fellow cruiser folks.
I want to do a super clean, reliable, sturdy, permanent trailer brake controller and hitch wiring install on my fj62 and would love to see and learn about what some of you may have already done. Where did you splice into what, what gauge wiring did you run on what path, what kind of brake controller are you using, etc. etc.
I've been doing some searching for help with my issues to no avail and am hoping some of you here might be willing to share their experience.
My current problem is that I've got a standard uhaul-installed 4 pronged trailer wiring harness inside my drivers side rear quarter panel already. It looks like a super crappy rats nest of wiring but appears to be installed correctly. When I purchased my trailer and hooked it up I found that it controls the brake and directional lights correctly but they are VERY dim. Too dim to be considered functional at all. I've double checked the ground wire and made sure it is connected securely to the frame and all looks solid but the lights continue to be dim. I even tried out a set of the magnetic tail light kits and they are dim as well. Im at a loss. Anyone have any ideas as to how I can fix this issue?
Because my trailer has electric brakes that my current wiring harness doesn't support, I must set myself up with a brake controller before I can start towing this thing. It weighs about 3000 lbs and the truck brakes obviously cannot support that kind of weight. I've found a few threads on the subject but am still unclear. Maybe I just haven't found the right threads ...
Excited to see what kind of genius installs people have done so I can augment my serious lack of wiring knowledge.
thanks,
Kevin
thanks,
Kevin
