- Joined
- Nov 14, 2013
- Threads
- 66
- Messages
- 567
- Location
- Huntsville, AL
- Website
- www.rocketcitycruisers.com
Ugh, ok guys, in my infinite stupidity on an engine rebuild on my 3fe I used a cheap head gasket. The gasket let loose and started dumping water in cyl 5. Pulled the head off to change the gasket (and have the head cleaned and tested). When I was cleaning up the block I noticed a crack on the block between the intake/exhaust pushrod ports on cyl 2, which has not been giving me issues and the compression was good om that cylinder. The crack could have been therr when o built the motor 3 years ago buy im not sure.
So here is a picture, thoughts? Replace the block or bolt the head and roll on?
