Hi all,
I have an 85 fj60 that has an interesting problem which started a few weeks ago. When I turn the key to off position the engine won't stop, and now will only start intermittently (it currently won't start at all). In the past, I have been able to hot wire it using a jumper to the ignition and start tabs on the back of the ignition switch. I have replaced the ignition switch with a new one - same symptoms. I have tried some ground troubleshooting - no help (that said, I don't see why a bad ground would keep it from turning off).
Not sure if this is a red herring, but letting it sit seems to help...
Thanks for the help.
Ray
Ray
