- Location
- United States
I need a trans tunnel cover plate. Its the part where the shifter boot screws into.
thanks. The production date is June 1967. It’s for a FJ40 H55 conversion.Might want to include your production date as these changed over the years.
I think you will find your going to need a lot more a 60 series inspection cover to install a H55F into a 67 FJ40. When I put a H42 onto my 68 FJ40 I used a transmission tunnel from a mid seventies FJ40. That is about a inch taller than my 68. Even than I had add washer to the front motor mounts which lower the back to clear the floor behind the tunnel cover. I trimmed the cover to the length of the one from the 68 and modified it along the right side. Think for a H55F would start with a mid seventies tunnel cover and modify the tub to use the full length of the cover. Then depending on the which top cover your using on the H55F would go from there what inspection cover to us. Correct 40 series would find one from a 83/84 40 series. 60 series would start looking for one from a 70 that raises the area. Either way my think of a small body for better clearance. I would go that route before lowering the transmission further below the frame.
[/QUOTE I already installed the h55...
I figure I will just modify a fj60 cover since they are easier to find...
I had no idea about the design change. Mine is the square one. Thanks for the offer...Do you still need the tunnel plate. I have one out of 82 fj60. Yes it's the round openings. Shape changed on and after Apr 1985.
Pm if interested.
Thank you
Send picsThe plate itself is the same. The change is only on the gear stick openings where the boot fits.
How much?The shape itself changed 4/85 in the US market. I have both styles. The early one have four square corners. The later the back left corner is at a angle. I also show a 8/80-10/82 even earlier. That one I'm not sure if the footprint changed or was just the boot change. Here is the pre 4/85 and later style.
Thank you living in the past for showing the difference. You are very informative on the cruiser parts. I have read your comments prior.The shape itself changed 4/85 in the US market. I have both styles. The early one have four square corners. The later the back left corner is at a angle. I also show a 8/80-10/82 even earlier. That one I'm not sure if the footprint changed or was just the boot change. Here is the pre 4/85 and later style.
