FJ60 SPEEDO Needle
I am trying to clean and re lubricate the Trip and ODOM on the speedometer. I started taking everything apart carefully. I got to the point where I need to remove the Pin that holds the shaft of the ODOM numbers. you can't real pull it out if the speedometer dial is there. That takes removing the Speedometer needle. Which I tried without success. Any tips or tricks?
I am working on the same thing. Did you find any answer? Matter of fact I broke the needle as I was cleaning it
