SOLD FJ60 rear hatch lock cylinder.
g-man
Charlottesville VA
  1. 60 Series
I need a rear hatch lock cylinder from an FJ60. The snap ring on mine is not holding on because the tabs at the back of the cylinder housing where the snap ring fits....are bent up. No key necessary. Doesn't even matter if the push button part is mangled. Just need the cylinder and a good snap ring at the back. make sure the snap ring is well secured in the cylinder.
NOTE...FJ62 has a different cylinder and will NOT work.
This IS your ONLY option G-man
i DO have this option available also , :)
PM me photos of ALL related parts you still have ?
thanks
matt
TOYOTA Certified Master Lock & Key Tech.
I mostly need the housing and snap ring circled in red. The spring would be nice too. My lock assembly is currently in my vehicle. But I have removed it and bent the tabs at the back of the housing a few times trying to get it to work. When I push the push button on the outside to release the latch, the snap ring is slipping back too far in the housing because the tabs with the grooves in them at the back are trash,/bent/weak. The button is traveling too far, the spring is going to far back and the linkage is moving too far as well.
i know this topic well
my kit CAN contain ONLY the housing and snap ring circled in red.
- if you like ? :)
HOUSTON : The TEq has Landed 🛬
- complete 3pc Exclusive SITH RED 2F Decal Kit
