I have a 1984 FJ60 with the TSM rear disc brake conversion kit installed. Have installed new pads and the rotors are within spec. Calipers were completely bled (pressure bled it) and the parking brake adjusted up. Problem is the brake pedal travels a long way (almost to floor), is spongy (like air in lines) and the brakes are not adequate (can't lock them up). Local mechanic believes the original master cylinder does not put out enough volume to move the pistons in the rear "Eldorado" calipers enough to get adequate braking effect. Anyone have experience with the same problem. Is there a bolt on solution which would provide additional fluid volume? Would a M/C from a FZJ80 work (bolt on) since they came with rear discs (and might have more volume)?
job. You'll have to bend a couple of brake lines and figure out how to connect the wires so your light doesn't come on all the time (I never did...)
