Wanted FJ60 Manual (21 Viewers)
does anyone have a front fender
Check out SOR, at $90 a pop on a brand new steel one I wouldn't fool with used unless it was easy and cheap.
Might want to use the wanted forum next time around. :D
Wanted-FJ40 Rear Step
thorvald- The top I have is actually really sweet. I had to make some assumptions on the size for the two windows on the back. The color isn't stock either, but it will look sweet. I am one of those perfectionists with my restoration, I get done with stuff and then think it should be better. Wish I had more time and money :D.
TJDIV- Thanks...I wish that one would work, but it's got the flanges out :(.
Merc, where are you. I've got a freebie, but I'm in KC
Ed
Need steering coupler
I've got one, used, but still OK. I'm in KC. 10.00 and I'll ship it to you.
Ed Long
Aun2th@aol.com :)
sm420 to 6.2 diesel bellhousing...
Just what the subject says. Need a sm420 to 6.2 diesel bellhousing. Thanks! :cheers:
wanted:76 oem floor mat
I'm looking for a rubber oem floor mat for a 76fj40 . Front and rear hopefully. I think 75-78 fit, other than that I'm not sure. thx
FJ40 rear Lift gate handle
I have a pair of struts, but they are kinda rusty. I bet they would clean up OK with a little elbow grease, though.
Re:FJ40 rear Lift gate handle
I will look and see what I had... I used to have several clean used ones but it seems that they are all breaking lately...
Early FJ40 side window replacements
Almost impossible to purchase from Spector, unless I want to drive to LA and pickup. Surely some other vendor sells the sliding glass side windows (with screens) that SOR has under p/n 321-40-WS. Any guidance would be appreciated.
Maintz
Re:Early FJ40 side window replacements
I know SOR has a contract with the company that makes theirs (CR Lawrance)... lots of $$$ but super cool sliders. I got a set of them for free once.. they now reside in my FJ40... :D
Re:sm420 to 6.2 diesel bellhousing...
should be the same as a regular 350 bellhousing........
FJ62 Drivers seat track
Does anyone have or know of anyone with a set of seat tracks, from the drivers seat of a FJ62 with a build date of sept 87 or later.
It must be from this period as the floorpan changed from the 60 series. ???
Thanks heaps. :cheers:
Longshot
I have a '77 FJ40 that needs a replacement tub-I have an Aqualu tub that I would like to trade-I know that this is a longshot-thanks for your help. :D
Longshot
I have not tried to put a hard top on it but, I don't think you would be able to drop one on without some mods to the lip.
Where are you located?
I have one but it is not pristine...
Tony in CA
