Wanted FJ60 Manual (1 Viewer)
A/C condenser
I need an A/C condenser that is in working condition. It needs to be for an fj60. My fj is an '87.
Please and thank you. Used is good. Cheap is great. I'm broke and very hot.
Check with Jim C, he probably has a few laying around for cheap.
80/450 front mud flaps
I am parting with my running boards from a 97 LX450 and noticed that there will be a gap where stock front mud flaps should go. Does anyone have some they would be willing to part with at a good price? I don't want to spend much since they will probably just get ripped off on the trails.
Thanks,
James
jamesgall22@hotmail.com
I have a '69, just took it out, column looks bent. Didn't realize it 'till I pulled it seems to work fine. Southern OR
Jim no got. I bought the carb from him. I found and just now ordered the part from cruiserparts.net for $15 - it would have been $70 at SOR (used)
thanks anyway!
Cruise1977 said:
FYI
Does any one know of a use for a 15mm wrench? If you have a thin one, it can take pedals off a bike, and it fits some modern car drain plugs. But they come in every wrench set with no use! I heard VW uses them.
Josh
US auto's use the 15mm as much as the Japs use a 14mm :D
Butch
JKS said:
Looking for a smog pump for a '77 FJ-40. I'm in So. Cal. (92627)
I have one.
Call me at 805-279-8041
If I don't answer, leave a message and a time to get back to you. In Ventura, So Cal.
Danny
For information purposes, I just went to the shipper yesterday with a complete 3rd in a 5 gallon bucket.
Central OH to Central Michigan. for 31 bucks through Fed ex ground.
it was 79 pounds.
BDS has them, You really need to check with the spring maker as some are different from others. CCOT sells them as well.
I have one in Columbus OH off a 75 2F if you need it. as with others dont offer too much.
Warren.
Does any one know of a use for a 15mm wrench? If you have a thin one, it can take pedals off a bike, and it fits some modern car drain plugs. But they come in every wrench set with no use![\quote]
Not a thread hijack, but a second response. I take my 15s and weld the mouth on the open end down to 14 and bolt them under the truck to use for checking the U-joints. I also grind open end on all the 16s out to 17s. ;)
