Wanted FJ60 Manual (10 Viewers)
Re:Trade? Roof/doors for Seats/RB/Tires
too bad you're not closer to colorado. i have two oem rollbars and a good fuel tank and i'd be interested in the doors.
Re:77 FJ40 Parts Needed Thanks
roll bar can't go ups unfortunately and i have no clue what truck shipment would be. for front cage kits, 4wpw has smittybilt weld in cage for 109.99. you also might try metaltech. i don't know what he charges, but i like the looks and much better fit and quality.
Re:OEM SoftTop Part Needed
Well -- I did find the piece over the driver's side door
last week so I have hope that someone out there has
the one from the passenger's side. I'll probably have to
wait a while ...
Fj40 Drag arm needed
I need the drag arm (the rod between the pitman arm on the steering box to the center arm) for my 76 fj40. Mine is bowed and I am getting a lot of flex in it due to my oversize tires.. IE: a bunch of play in the steering.. Anyone have a decent straight bar they want to sell?
Re:Fj40 Drag arm needed
I have one off an 1980 fj40 if you are interested. I will be going to saginaw very soon. Give me a shout via email. ;)
NuclearLemon,
Could we send the roll bar on Greyhound? I'll call tomorrow to see what they think. How much are you asking for the rough bars?? Thanks
found another driver's side one today and know of two more in Vega$ (at different locations).
the right was not to be found at my friends stash though...
Kick out vent setup
Anyone have the springs for the small kick out vents that they want to get rid of? I need the whole setup except for the vents themselves.
Thanks.
Need seats/tires
Looking for stock seats for my 75 fj40, frames and springs need to be good, ok if need recovering. Here's a long shot, looking for 35x12.5x15 tires (5) used or cheap, if someone has upgraded. Prefer items located in Fla or southeast. Also have some items for sale/trade, stock tire carrier, exhaust manifold, skid plate, all off the 40.
Brake Fittings Needed
I need brake fittings all the way around for a '63 40. I believe they are 8mm x 1.00, only made by toyota, only on 40's 'til '69-'70 something like that, then went to 11mm fitting. Also need the accompanying t's if someone has this stuff, would be lifesaver.
need lift for 83 fj60
I have a stock fj60 . I am looking for set of used springs hoping for at least 2" lift, any help would be appreciated. Best if in colorado vicinity
Re:need lift for 83 fj60
good luck dude. I've been trying to hook up a lift for my 60 for ages now. Its mad hard to get a lift (in good condition) for cheap. You may have to bite the bullet and buy one new.
Re:Kick out vent setup
sup bro,
anything for another guy with a 72 :D. i've got a set of kick vents layin around somewhere. i'll find em and mail you the springs.
do you need any other parts than the springs? tell me and i'll see what i can do.
i'm goin to email you right quick, so either reply to that or post your mailing address so i can get em to you.
jonathan
jmalphr@clemson.edu
Re:Need power brake adapter for '69 FJ40
:Your in luck. I just so happen to have a brand new WARDENS addaptor& rod that I was gooing to use on my 69 fj40 but ran into clearance problems with my Holley carb. Its yours for 90$ and any shipping charges.
thanks
Scott Vigne
TLCA#12755 8).
Re:2"- 2.5" Spings for FJ40
I have a full set of Rancho 2.5 inch springs complete with 2inch shackles. Every thing is approximately two years old for a fj 40. 300$
THANK YOU
Scott Vigne
TLCA#12577 :o :D
Blythe cal
$50 for the rough bars, sound ok to you?
Re:Need Early Style Windshield Hinges
did you ever get the hinges? if not, i've got a set on ebay and i might have another set downstairs. let me know.
FJ40 Rear Heater
I am looking for one, dont care how it looks, just need a working motor from it. Any help (and a cheap offer) would be great!
Thanks,
Rob
