roll bar can't go ups unfortunately and i have no clue what truck shipment would be. for front cage kits, 4wpw has smittybilt weld in cage for 109.99. you also might try metaltech. i don't know what he charges, but i like the looks and much better fit and quality.
Well -- I did find the piece over the driver's side door
last week so I have hope that someone out there has
the one from the passenger's side. I'll probably have to
wait a while ...
I need the drag arm (the rod between the pitman arm on the steering box to the center arm) for my 76 fj40. Mine is bowed and I am getting a lot of flex in it due to my oversize tires.. IE: a bunch of play in the steering.. Anyone have a decent straight bar they want to sell?
Looking for stock seats for my 75 fj40, frames and springs need to be good, ok if need recovering. Here's a long shot, looking for 35x12.5x15 tires (5) used or cheap, if someone has upgraded. Prefer items located in Fla or southeast. Also have some items for sale/trade, stock tire carrier, exhaust manifold, skid plate, all off the 40.
I need brake fittings all the way around for a '63 40. I believe they are 8mm x 1.00, only made by toyota, only on 40's 'til '69-'70 something like that, then went to 11mm fitting. Also need the accompanying t's if someone has this stuff, would be lifesaver.
good luck dude. I've been trying to hook up a lift for my 60 for ages now. Its mad hard to get a lift (in good condition) for cheap. You may have to bite the bullet and buy one new.
:Your in luck. I just so happen to have a brand new WARDENS addaptor& rod that I was gooing to use on my 69 fj40 but ran into clearance problems with my Holley carb. Its yours for 90$ and any shipping charges.
thanks
Scott Vigne
TLCA#12755 8).
I have a full set of Rancho 2.5 inch springs complete with 2inch shackles. Every thing is approximately two years old for a fj 40. 300$
THANK YOU
Scott Vigne
TLCA#12577
Blythe cal
