Wanted FJ60 Manual (15 Viewers)
Re: OEM radio blank/cover
I'll look. Thats the kind of stuff my wife hides as soon as we get it. I'll also ask her when she gets home.
LOL, lemme know if ya turn it up.
John
stock disc brake 40 or 55 wheels
Looking for a nice set of stock disc brake 40 or 55 wheels, need to have the hub cap clips in good shape, no dents or rust(a little surface is OK) don't care about paint.
Would prefer to find a set in WA State as shiping em(unless the price is very right) doesn't make much sense.
Also would like a set of the latter(80+) fj40 white(not chrome 60/2) spoke wheels, I would be OK with shiping these.
Thanks
John
Re: Rear Flat Springs
i've got a set of springs off a 77 fj40 in the denver area.
Does your set has the botton srping (single one) flat that ususally is very thick?.
Problem: I'm in NY.
Let me know.
Dan.
Re: 4'' lift shocks wanted
All lift springs have differant atriculation, you should flex your rig out and see what the compression and length is for your application and then find the shocks that you need.
Re: Need Rear End in TX-OK Area!
Jon do you need a complete axle or just the 3rd member?
I have either and am in Bonham, Tx. 70 mi north of Dallas.
email me at butchbaker@cableone.net
Butch
looking for DUI distributor for '67 fj40
I am looking for a DUI distributor for my '67 but would also pick up a non-USA points type distributor if it is solid and cheap enough since I already have a Pertronics electronic ignition kit.
Cheers,
Matt
I've got a pallet full of stock FJ40 springs here in Nevada :givemebeer:
George; I only need the botton piece, but I don't think it ever came with the FJ40, only with the 45.
Let me know, I'm interested.
Re: looking for DUI distributor for '67 fj40
Look in the tech section and make your own! I used junkyard parts and a cupple hours work and now it runs better than it ever has!!! chevy 250 6 cilender engine big cap with coil.
Re: Looking for PTO drive
Evan,
You say on the back of the transfer case. On my transfer case, the drive would bolt onto the driver side of it. Is that what you meant??
Thanks for the reply
Geoff
81 BJ60
what vehicle are you looking for? ask cruiserdan, if theres an oem part he should be able to find it. thread labeled "hole" on 80's list has a part number for to cover half the hole on a double din cd for 80 using single din, so they probably make others. around 30 bucks though. :wave:
The ramsey PTO box will not fit...it only fits on the 3spdeed transmissions and transfer cases.
The pto works off the transmission to transfercase input shaft and replaces the rear bearing cover on the transfercase...hope this helps...oh and if you have a split case transfer then you will need a diffrent one from the non-split PTO one.
Stew
If your split case does not have the gear inside the case. I have a brand new one in the Toyota box if you should need it. $40 plus shipping.
2"- 2.5" Spings for FJ40
I need 2" lift front springs for my 40. Tired ones are OK. Will take all 4 if the price is right. SF Bay area.
sorry I wasn't more clear it's for a 82 fj40(or earlier but there slight variations)....it's an discontinued part. All it is is a plate to cover the hole(but says Toyota) as the AM radio was an option, the cover was to hide the hole if no radio. I have a cover from a bj60 which sorta fits but i would like the correct one.
For the most part I have all the part numbers(fisch, CD, books) and pricing for OEM stuff going back to the early 60's.
John h
