Wanted FJ60 Manual (1 Viewer)
I need one that has no hole (I could plug it) but it must have the clamp ring around the base of the inlet to tighten it to the carb...
My carb has an approx. 3.125" OD for the air filter... is your about that (the one that was bing used looked alot like yours on the right)
Thanks!
Where are you, ats72fj ??
Air Cleaner Assembly
Kurt,
I might have one. It is from a 1971 FJ55. I will look and see if it has the hole or not.
Friendly guy wasn't he?
I cut a piece of sheet metal to size, painted it flat black and siliconed it on. Been there for over a year. Even holds mi cb mike. Didn't cost a dime and looks good. My .02
Later,
but they look nice :D
Thanks guys for the quick responses. Kurt, sounds like your top is a little too nice for my needs. I'm hoping to find a top for a couple hundred bucks.
wrong coast, I've got access to a 63 in decent shape.
Here is one picture. Am having real trouble with resizing pictures currently. Apologies. Will find out Monday how much to ship. The wheel on the end was the spare, and has a little rust around the inner edge. The remaining 4 tires have a minimum 7.62mm (0.300in) tread depth. The spare is much more, but a different tire.
Groucho
sup kurt,
i may have an old one with a good covering of surface rust on it...i'll check it out tonight when i head home and let you know....
malphrus
Hey looks not to bad at all
You think that spare rim would scrub up,it's kinda tough to see how bad it is in the pic the others look good though, course that rusty rim might distract from the rust on the fender :)
2F water pump,fan,and pulley...ect
I'm trying to set up my 40 with a few more accessories. Need to convert my 73 F to handle 2 belts. Anyone have a 2F pump with fan and double groove pulley? I'm also going to need a mount for a sag power steering pump and toyota box mount. I'm just west of Sacramento, so one in that area would be great.
Thanks
Dave
i have some of the hood hold downs, but not sure if they'd be any better than what you've got already....
i got some nice shiny ones from ccot, not too bad of a price either...
malphrus
