Wanted FJ60 Manual (62 Viewers)
try the dealer I just picked up a pair of em for less than $20 each.....:)
tucker74 said:
I know - I was trying to win the set of fender emblems off it (with all the studs!).
Bummer!
Maybe someone will bring it back to life :)
Tucker
Steve, thanks but I already know several sources for new ones at about $100/pr. I guess I should have been more specific in that I'd like to acquire some used ones for substantially less. Thanks anyway.
Mike
looking for horns for 73 FJ-40
Looking for a set of horns (high, low) for my '73.. Mine still work sometimes, but they are cracked and the housing is broken.
Anyone have a set around??
Let me know.
Rob.
I have a set from a 78FJ40 if you are interested.
3.7 Speedometer Gears
I need the 3.7 speedometer gears from a split case transfer (86 Bj74).
I have 4.11 gears I'd love to trade but I could buy as well if 4.11's aren't needed.
I'm in Moscow, ID 83843 and would rather not pay the $35 at the dealer for the gears.
thanks
-mike
Parts Needed for a 78 2F
I'm looking for an Alternator Bracket that mounts to the P.S. of the block and a 2-groove Water Pump Pulley that would fit on a 78 FJ45 2F. If anyone has anything out there, please drop me a line.
Holley to 2F adapter
Anyone have the carb adapter to adapt the Holley/Motorcraft carb to the 2F manifold?
Holley--->2F adapter
I'm 99.44% sure I have one, along with a Holley 2BBL and air cleaner and extra float bowl and some other extra parts along with it.
Any of the extra stuff needed, or just the adapter? I sell stuff cheap, pretty much a few bucks for the trouble of packaging, and then the actual shipping cost.
Dianna, are you looking for the aluminium ones? I've got an extra set, not perfect, but should work for you. Paul
You should be able to buy tht at most any Autozone etc.... Very common bolt pattern.
David, what do I look for on the bolt pattern? I didn't think it'd say Holley to Land Cruiser 2F. :D
Is the 2F intake bolt pattern equivalent to something else more common?
Desertdave, if I can get one locally I won't put you through the trouble. If I can't I'll e-mail or PM you. I just need the adapter.
Thanks.
I have the adapters that came with my 4412 Holley as well if anyone wants.
Thanks
