FJ60 Emissions help
Bagaces, Costa Rica
Website
geckoridge.com
I live in Costa Rica and have 2 USA FJ60's. I am having a lot of problems with the emissions equipment on both. No one here know how to work on that part of the car as they do not use nor require emissions. Does anyone know or have any experience removing the emissions equipment from the 2F gas motor?
Thanks
Search....
Tons of de-smog threads. But do it right and the truck will run better
Benn there, done that... twice.
I've done two desmogs on FJ60s. It was shocking how big the pile of garbage was! Both times I replaced the stock carb with a Weber. The end result was beautiful! The carb had only a wire to the electric choke, a fuel line and a vaccuum advance hose going to the carburator, plus the air cleaner and PCV going into the carb base. CLEAN! and they run better without all that stuff. I ran headers with both, so we had no more need for the cooling fan since vapor locking never happens when the exhaust manifold isn't bolted to the intake manifold. All sensors, twelve miles of tubing, the guts to the air pump, air tubes to the exhaust, all gone. It's enough to make you cry when look at how elegantly simple the whole engine is like that, and you know what all the parts are!
