I just found this thread and read through from the start. I have had a 94 K2500 (F vin) 6.5TD pickup for three + years now, and love it. You'll find lots of information about the 6.5 on these two forum sites. thetruckstop(dot)us and dieselplace(dot)com also, you'll find Leroy at leroydiesel(dot)com very helpful, he's very good at answering your questions. 1993 was the last year of the mechanical IP, and 94 the first electronic IP. The pump mounted driver (PMD) which was mounted on the side of the electronic IP should be remote mounted (not in the engine bay) for longer life. The best way to do the remote is with an extension harness. The harness and PMD can be found at leroydiesel, and other places. The harness is about six feet long and allows you to move the PMD completely out of the heat under the hood. I moved mine to between the bumper and radiator, which does get a lot of air movement. Most people move theirs to somewhere in front of the radiator core support. As to your oil cooler question. The 6.5 has a cooling problem and came with a stock oil cooler that was mounted in front of the radiator. I'd highly recommend finding a place to mount a cooler as that will provide a lot of help keeping the temps under control. Also, if you have the room to do so, I'd suggest getting one of the plastic 9 blade cooling fans from one of the early Duramax diesels. The blade is a bit bigger than the stock metal blade you have. It is also a direct bolt on in place of the stock fan. You may need to do a small amount of trimming on the fan shroud for clearance, I did. The stock GM4 turbo does OK, but you may find it falls flat over about 2500 RPM. Numerous 6.5 owners have been working on turbo swaps for better MPG and HP. One guy, known as WarWagon on the truckstop forum went to one called the ATT (A Team Turbo). He's a hot shot hauler, using his 6.5 vehicle and a trailer, delivering to northern Arizona. He's found that the ATT has improved his mileage by about 3 MPG, and has increased his speed as he tops out the long grades. Others that don't tow all the time have had similar reports about the ATT turbo, and a few other turbos as well. A different turbo won't be high on your priority list at first, but something to keep in mind. I could write a book on what I've learned in the last three years about the 6.5. Those two forums I listed were my teachers. If you have any questions I will try to answer them. Best of luck with your swap and I'll be watching your thread. If you ask a question and I don't get back to you right away then send a PM to me as sometimes I get caught up in things here around home and don't get to check Mud every day. A PM will get my attention as soon as I log onto Mud. I feel like I'm forgetting something, but not sure what at the moment. I had trouble sleeping so that is why I'm up at this unearthly hour. I'm starting to feel sleepy and my mind is getting fuzzy so I'll see if sleep is coming my way. Don
