what the plus of the 6.5 diesel over 5.7 gas setup?
Low end torque/mpg/wvo/durability/no electronics
like her said torque mileage way less wiring. Durability. And here in Utah it makes me exempt for emissionswhat the plus of the 6.5 diesel over 5.7 gas setup?
this one is electronic sadly but it's all plug and play and ten times less sensors then a TBI setup on a SBCLow end torque/mpg/wvo/durability/no electronics
he not her sorry!like her said torque mileage way less wiring. Durability. And here in Utah it makes me exempt for emissions![]()
yes I just rip the wiring out and put a mechanical 6.5 pump on which I thought about but I hear like you said the PMD is the biggest issue because it gets hot. The guy I got the truck foe replaced it before I got it so I was gonna run with it until it dies then get the relocating kit from ssdieselsupplyYou can convert it back to all mechanical if you wanted, but I believe if you relocate the pcm to a cool place you eliminate one of the biggest problems on these engines.
thanks! I sure hope so!lookin good man thats gonna pay off real soon.![]()
I will be the first to agree with you that these are not all stars in trucks. I personally think it was stupid in a truck however in a Landcruiser that will never see a trailer behind it and weighs less then the truck. It's perfect. And more durable in ways and less in some. And as for paying off in mileage or any aspect it's not even on my mind I figure if I were to be smart with money I wouldn't own a cruiserI can't buy the 6.5 or 6.2 is any more durable than a 5.7, I can agree the fuel mpg is better and the torque range is lower in the RPM range, but given the fuel price...and how much you drive it...will it pay off there...the additional range would be nice if you drive it much. I don't know the torque number for the 6.5 or 6.2. Both engines were not "all-stars" in the gm pickup line back in the day. Not here to argue about all of that that is the truth, many GM pickup owners had the 6.2 and 6.5 removed for a gas hog v8 replacement. As noted depends on what you have 6.2 or 6.5 in regard to electronics.. I can confirm the 6.2 and 6.5's are diesels so that's a plus for some people I guess. A number of guys have them... two guys in my local club. it it works well for you then that's all that matters, good you got the donor truck. I think there are some known mods to both engines to make them more dependable than they work back when they were built. You might want to look into some additional sound insulation....the engines are loud.
thanks! It took some trimming but it fit great after. No a/c motor didn't come with a pump or option on this truck which doesn't bother me. I don't care if I have it being I run half doors in the summerlooks good so far. The fan shroud looks like a great fit. Are you planning on running A/C?
I don't know about that particular kit, but when I looked into this for a friend what I mostly found was that they were just a fairly simple bracket, the wiring loom is long enough as-is to move the PMD out of the heat and up into some airflow.yes I just rip the wiring out and put a mechanical 6.5 pump on which I thought about but I hear like you said the PMD is the biggest issue because it gets hot. The guy I got the truck foe replaced it before I got it so I was gonna run with it until it dies then get the relocating kit from ssdieselsupply
I haven't really read up much on how to do the mod. Do I move this whole piece or is it just a sensor I move or what?I don't know about that particular kit, but when I looked into this for a friend what I mostly found was that they were just a fairly simple bracket, the wiring loom is long enough as-is to move the PMD out of the heat and up into some airflow.
