FJ60 Clutch slave cylinder bleed & adjust (1 Viewer)
Salt Lake City, Utah
Howdy all,
Planning to replace the clutch master cylinder and slave cylinder tomorrow. Got a few questions.
Order of operations, I was thinking replace slave cylinder first, then bench bleed master cylinder and replace, then bleed the whole system. Is that wise? Or should I replace clutch master first, then slave cylinder?
And, how do I bleed the system? Read a few forums about gravity vs other methods. My girlfriend and I are doing it together, so I have a buddy. The slave cylinder has two holes on one side. Male on top with a little nut and rubber cap, female on bottom. Is the one with the rubber cap the "bleeder valve"?
Replacement slave is adjustable. How do I know what the proper adjustment is when installing?
Thanks for any tips and info. Wish us luck!
