Hi all,
Sorry if this has been documented elsewhere - I did several searches and went through many threads but couldn't find the info I'm looking for.
I have an Fj60 made in July of 1985 that has the 4-speed gearbox with the spacer that (I'm told) makes is a candidate for a direct swap with the H55F 5-speed.
I've got one in the cart for $2750 along with the shifter, knob, gasket from trans to t-case and OEM Toyota H55F Oiler Pipe - Fits H55F & Split T-Case Applications (TR36010).
Is that what I need?
Some vendors I went to said I need plugs for extra bolt holes - what are these and where do they go please?
Also 1/4 tap (if this is for tapping/threading something I think I have one already) but what do you need to tap and why?
and where does the oil pipe fit?
Other threads on this topic recommend having bolts that you cut the heads off and use as dowels, but I can't picture where or how during the re-install they go?
If there is a thread with the full procedure then please point me to it - many thanks in advance.
Background - I think my 2nd gear synchro is bad, shifting is difficult and getting worse when on the move unless you get the timing just right and there is a whine in 4th that I don't like (plus a fair bit of glitter in the trans oil when I changed it about 6 months ago). If I have to take it out anyway then I figure why not get the upgrade. my level of aptitude and experience is piss poor although I have removed and replaced the head and block to get them rebuilt - don't ask me how I go the engine back in without taking the trans out, I'm still not sure how I did it. Car has 203K miles on it I think it was at 190 when I got it and 4k since the engine rebuild.
