Quick grounding tips:
1. Most lighting ground problems are in the light housings. Toyota relies on the housing to ground itself to the body/frame. Rust will eventually cause the ground to be lost or become intermittent. The lamp sockets (where the bulb goes) also get corroded. The solution is a Dremel tool with a wire brush mounted to clean the sockets and housing to body/frame contact point.
2. The wiring system on an FJ40 has a few grounding points that need to be addressed.
A. The main ground for the system is of course the battery negative cable to chassis. There should be TWO grounds: One from the battery to the frame rail, then from that point a short jumper cable to the starter mounting bolt on the engine block. This provides the frame and engine block with good solid grounds. Note that the engine is mounted to the frame with rubber isolators so the engine may not be grounded well through its mounting bolts, IE the reason for the jumper. Engine ground is really important for the starter AND the alternator to function properly. Also idle solenoid, temp sensor, and the oil sensor.
B. Next are the wiring harness grounds. The primary harness ground on older trucks is located at the external regulator. There is a WB wire that comes from the harness and attaches to the regulator E terminal. The E terminal is directly connected to the regulator case therefore the regulator case MUST be well grounded to the body! This ground is critical! It is the ground wire for the alternator, headlights, VSV, heater blower and wiper motor!
The rear chassis harness ground is located under the truck on the passenger side frame rail about where the t-case is. There is a brass ring terminal with two WB wires going to it that is bolted to the frame. This ground is only for the t-case 4WD light and the fuel gage ground.
Everything else on the FJ40 grounds to the body or chassis through its mounting bolts.
So when someone say to check the grounds now you know what to check.
