EDIT: Vibration solved. I still need to correctly set my bearing preload. Shims ordered. My fix in post 5.
I am having drive line vibration unlike the common symptoms. Start at about 50 MPH and very subtle, if any, under load, but very noticeable coasting or between accel and decel loads. I checked the rear driveshaft and there is minimal rotational lash in the splines and U-joints appear good-no slop and smooth.
But, the parking drum has in-out and lateral movement. I suspect this is the cause. I cleaned the TC and replaced seals and shimmed it the same as I disassembled, thinking it was correct. Clearly, I know now it is not correct.
I think it had the vibration before I did the work, but I seldom drove it that fast. I now have a 5 speed OD and an LS so I'm driving the higher speeds more often. Also have better tires and a hard top so these vibrations are more noticeable.
Looking for opinions if the loose output is the cause. Well, the more I think about it, I need to correct this first and see if I need to go further.
