Fj40 headers?
I purchased the man-a-fre for the 77 project, plus my neighbor has them on his 76. The y pipe fitment needs adjustment to clear the FJ40. I figured I’d try the SOR headers this time since they advertise a fitment above the skid plate.
Good information, thanks!
It looks like I am pretty much stuck between the SOR and the Man A Fre header. Any recommendation between the two? I will need to dive into the 3FE header conversion a bit more but it does appear to be a plug and play scenario.
I will probably go with the 3FE as well.
I actually have had success with the JT but now see they have further reduced quality (as I confess I have a new one in the garage and the ones I used were 10 to 15 years ago). The only way to make one of the JT Outfitters headers work is with a Remflex gasket and some washer magic. One can order a set of very thick washers on Amazon. Torque to specs and pray.
Both if them I have used worked.
If you use a 3FE or stock believe Mark and use a good single gasket with copper sauce. No reason for a Remflex when using OEM iron.
I guess a problem for those of us building a truck, you do not want to set up for a header and then have to get your new exhaust modified or replaced for a 3FE or other manifold.
I just did this recently on a 72. I put in longer studs, thicker washers and flange nuts for better clamping force.
Where did you find your 3FE manifold and are they all the same between the different years?
I installed a used header on a F engine. I quoted the comment about a JTO header.
What are 3F manifolds worth. Somehow I ended up with a pair…about 25 years ago.
Just put out a want add in classifieds. I bought a set locally from a want ad off MUD, i think I paid $150 for the pair of manifolds.
3FE or 3F?
3FE manifolds, 2 piece, 1 for front 3 cylinders and 1 for rear 3 cylinders
3F manifold is very similar to 2F manifold
I've sold 2 or 3 sets of 3FE manifolds with heat shields and small down tube stubs for $150, in the last 2 years
there was a thread in the 60 tech section, maybe by @Godwin ?? about this subject
