Here is a set of Marks Off Road/ Downey headers that I had ceramic coated inside and out.
Count me in for a set of "Downey" headers if a run is made. SS please.
I’m in !!
It is not.For sale?
My headers almost look like those,but very slight differences...Mine were originally chromed but almost no chrome on them-just rusty steel...I had manifold leak recently so I evaporust them,sprayed them with coats of VHT hight temp primer and VHT ceramic coating-few coats--waist of money...Ceramic coating was cracking on the way home and I did exactly as they said..please do not buy them VHT header ceramic spray paint-waist of time and money!!!Who coated yours?Here is a set of Marks Off Road/ Downey headers that I had ceramic coated inside and out.
Mine was also chrome, I took it to a professional shop that charged me $95 to ceramic coat it. They did both inside and outside, I have a life time warranty.My headers almost look like those,but very slight differences...Mine were originally chromed but almost no chrome on them-just rusty steel...I had manifold leak recently so I evaporust them,sprayed them with coats of VHT hight temp primer and VHT ceramic coating-few coats--waist of money...Ceramic coating was cracking on the way home and I did exactly as they said..please do not buy them VHT header ceramic spray paint-waist of time and money!!!Who coated yours?
I use Embee Performance. They have 8-9 colors to choose from and do the copper coating inside. I chosed Tungstun for the outside color.would you mind to let me know which shop does that?I wish I did it this way...Thanks...
I have these same headers on a 1.5F (1/71 build). There is no bolt/stud at the front of the header flange (closest to the radiator), nor is there any provision visible to install a bolt in this hole. They leak at the front. Are you're headers/head the same way (no securement at front of header)? Are they leak free?these will warm your burritos while adding some torque
I was silenly hoping we would find a solution.Stan is retiring; he put his business up for sale last week.
Ahh man that is bummer. Thanks for the update. I will be watching to see who buys him out.Stan is retiring; he put his business up for sale last week.
Someone here mentioned milling the 3FE header flange so it was the same thickness as the intake flange. I made half moon washers instead to make up the difference. My 3FE headers came with the downtubes which I was able to flip and fit to make my own collector, so if you can get those as well it's pretty straightforward.It looks like I am pretty much stuck between the SOR and the Man A Fre header. Any recommendation between the two? I will need to dive into the 3FE header conversion a bit more but it does appear to be a plug and play scenario.
