FJ40 4spd shifter problems
I have a 76 FJ40 w/ chevy 350, Toyota 4spd transmission, Toyota 3spd transfer case -I have it down to the frame and just started the frame / rebuild.
The engine mount is home made, mounted to the front of the block and uses the stock FJ mounts. the transfer case mount is a better quality aftermarket.
the transmission is pushed forward, the hump was cut and the shifters heated and bent. is this normal how do I get the trans back in its proper spot?
