Lusting after my vice Lou? I'm Kinda ol fashioned that way. Keep your mits off of her. You do know that the pins I am sending you are finished? Sorry, sometimes it takes me awhile to figure things out. You are going to make pins anyways, right? I forget that some of you guys have more than one Landcruiser. Kinda ol fashioned that way too. Slut! Okay, maybe a little jealousy. Your vice might be able to do this part if it has the right type of removable jaws. You might be able to buy another set of notched jaws that bolt on. If your vice is sloppy then there are ways to deal with that. I like to use this particular vice for its' quick release feature. The machine ops. we will be doing don't require alot of clamping force. I don't know how much time you have spent in a real toy store. Here in cold swamp Or. I get my machine tools from Hall tool and Palm Abrasive. The guys down at Hall are great and help me out all of the time with the part sticking above the Carharts. Palm has everything. I am betting Tuscaloosa is big enough to merit these types of Vendors. That particular vice design is relatively common. I'm betting you can track one down easy. Might have to shell out a couple hundred for a good one. Last time I was in Harbor Freight they had a McCheesmo version for mega cheap.by the way; what brand an modle is that cute lil drill vise?
Lou
very little in machine shop items or suppliers here in Tuscaloosa........have a HD and a Lowes but that is it.......have been burned on harbor freight "bargains" like their 157 drill bits for 17$ that won't drill through preserved wood
still haven't given me her phone number.....
I mean brand and model
You know, as far as the brand and model of the vice goes, I just can't tell you because there are no identifying marks. It is an oldy. My Grand and his Brother were into Craftsman way back. Alot of my stuff comes from them. Ya, know what you mean about Harbor Frieght and cheesy drillls. Boys down at Hall set me up with some Triumph 110 degree tip stuff. Drills like a dream. Since getting tools is more difficult for you, you might want to get started on some of the other tools you will need. I would suggest picking up a #4 center drill and an adjustable reamer with the large size being 3/8. Another item you might consider is a 9.5 mm twist drill. You will need to drill your hinge strap and stay strap to a slightly less than 3/8 ID. The 9.5mm should give you a 0.001" to work with. The U drill size leaves too much material but if you have a U in your box already it will do the trick. If you have a really good hardware store around they might be able to help. Maybe Grainger. Keep in mind that there isn't any real time frame to sweat. I am hoping to get around to actally starting the job Sunday. Monday, I will be picking up tooling and drill rod. So Monday might be a good day to get your stuff too. if worse comes to worse I mght ship small stuff I get here for you. As far as seeing any more pictures of the vice you can forget about it until I see one of your girls. With the doors closed, you know, tasteful. Frontal shot, no bra!thanks for the pinsvery little in machine shop items or suppliers here in Tuscaloosa........have a HD and a Lowes but that is it.......have been burned on harbor freight "bargains" like their 157 drill bits for 17$ that won't drill through preserved wood
, better to get one good bit than a great big box of useless ****!.............and yes, am lusting after your drill vise
Lou
, had lots of play and used the lift the door and if it wiggles but the body stays the same then the hinges are junk technique.......yes, both were...........problem is other three doors need fixin also!......by the way, what are you thinking about inserting in between the hinge and stay strap? originally there were some plastic bushings.....and am lost when you are talking allen set screws, are you thinking you need them to hold the pin in place?I am dying laughing right now. When I did my DD no plastic hinge bushing present. Thought that they were pin on cast iron all this time. Today I had a close look at my DR hinges, finally saw the plastic bushing. Now! you tell me Lou. Too funny. What all this means is that there is now only one size to consider. Of course, it is possible to go above 3/8 but probably not a good idea. Anyway, I believe you asked what I planned to replace the plastic bushing with. Nothing, that is right, with the grease present, wear or rust should not be a problem. The cast iron surface of the hinge is actually a good bearing surface with lube. Hey Lou, Did you buy replacement hinges from SOR, not a rebuild kit? And they are junk? If so would you do me a solid? I am dying to know, did they drill out the Stay Strap? That is, can you see that they used a larger pin than stock? The stocker is 0.3125. The 1/4-28, 3/16 allen set screws are indeed used to hold the pins in place. I drilled the back of the stay strap, tapped 1/4-28 and set the screw threads with loctite blue. Paranoid about those pins dropping out. I was thinking that a set of vice grips would be able to make the knurles. Just crank em down on the last 1/2" of the pin. Maybe not have to drill and tap the stay. There has got to be natonal tool supplier out there that does the internet. I will look into it. Anyways, I should have another set of hinges complete tommorrow. And fresh pictures to complete the thread with. If your SOR built hinges are junk, then you will be happy with the results of this technique. Honest, mine are tight as a virgin. Ouch, rip my heart out talking about Monarchs and Bridgports, ran and appreciated both. I they start s****ping Hardinge lathes, and Tree Mills then it's WAR baby.just finished doing both DD hinges on the piggy used the $OR replacements that I had already bought before this thread came about, had lots of play and used the lift the door and if it wiggles but the body stays the same then the hinges are junk technique.......yes, both were...........problem is other three doors need fixin also!......by the way, what are you thinking about inserting in between the hinge and stay strap? originally there were some plastic bushings.....and am lost when you are talking allen set screws, are you thinking you need them to hold the pin in place?
Lou
