(FIXED) BJ75 Troopy, swapped transmissions, now fuel gauge dead
nuclearbeef
Memphis
1985 BJ75 Troopy with H55 and vacuum split case.
Removed H55 and case and replaced with 1987 H55 and manual split case from a BJ75 Troopy.
I failed to pay any attention to the plugs when I removed the trans. I figured it would be impossible to get them wrong.
Nope. Fuel gauge not working now.
I originally plugged the black, 2 pronged plug coming from the fuel tank into a white connector on the transmission wiring harness because it fit.
After seeing the dead fuel gauge, I found a black connector on the harness that also fit and swapped the tank plug over to it.
Still dead.
Did I kill my gauge, or is there something else amiss?
Update...
After chasing down some blind alleys (including swapping the transmission wiring harness), I believe I have isolated the issue.
Fuel gauge never moves off the empty pin.
Disconnected the cannon plug between the back of the transmission wiring harness and the fuel tank.
Ohmed the 2 pins to the tank. Open. No continuance.
Placed jumper wire between 2 pins on plug on the transmission side... Fuel gauge went to full.
Sending unit on order from Partsouq.
I guess it was just coincidence the sending unit went bad at the same time I swapped transmissions.
