Finally went wheelin'!! NOW I think I understand....maybe
Richmond, VA
Ok, went up into the mountains this weekend to take the family camping. Just happened to have a few trails up there that were a lot of fun! Here are some of my observations, and questions:
1) The factory roof rack had to go. I opted for a Yakima MegaWarrior rack as it was readily available and I can do many things with it. MUCH better than factory. Used the trick from this forum and put some screws with special metal/rubber washers to seal up the holes. Thinking I may put to more bars and the extension on there, but not sure. Anybody had any bad experiences with Yakima stuff? Probably not as rugged as the ARB or Safari stuff, but at less than half the cost......
2) Factory spare tire position IS a problem. I need to either move it higher, or put a new bumper on the back and mount it back there. Could mount it in the Yakima MegaWarrior basket (has anyone done this?).
3) Factory tow bracket is way TOO low. Maybe with a higher lift thiis might be ok, but I scraped it numerous times. Even lost my Toyota cover for the hitch mount hole. :mad:
4) Stock suspension is not really setup for a load on top, 2 adults, 4 kids and a dog!!! At least the rear. My LC was doing quite a bit of squatting on the way there. And even after the load was removed and it was just the family and the dog, it still was squatting a bit. Could be 7 year old springs/shocks, could be it wasn't meant to handle that. Either way, I have to do something.
5) Suspension height is too low for the "fun" stuff, specifically in the back because of #3 and #4. Did ok for the most part, but had several scrapes that concerned me. Almost all were the rear end (probably the hitch mount).
6) Michelin's did fine for the stuff that I was on, but I would have preferred something a little more agressive (and taller).
7) LC has some serious "umph" for an inline 6 pulling/pushing 5000 lbs! I had no problems with anything, except of course with it was too steep because the rear end was dragging.
8) There are some squeaks underneath that I need to figure out. Probably nothing, and I may be expecting too much for a 4x4 suspension to not squeak when being taxed, but I would rather know....
9) Running boards faired well. Heard some things catch them every once in a while, but no big bangs or such. I'll keep an eye on them for now. My wife (5'1") says that if I lift the truck, put on bigger tires and remove the boards, she won't be able to get in. Ummmmmm, I think I will leave that one alone!
10) Only casualties were the cover mentioned in #3, and the factory antenna that used to go up and down now only goes up about 2 inches and then back down. Not sure if dirt/mud got in there or what. Will clean and see what happens. Did have a large loud clank in the rear going in/through one big puddle. Could have been the hitch again, but I will be checking everything underneath today as I clean it up.
11) Brakes. Seemed to do ok, but on the down hill parts, I am sure they heat up quite a bit. Drilled rotors would be helpful, but I understand the downside with rocks and mud. Need to read some more about this. Any input is welcomed!
I was/am VERY impressed with the LC and certainly am glad I bought it. I had always wanted one, hearing and thinking they were work-horses, but never knew for sure. It's not indestructible and at 5000# there are things I am sure it cannot do, but for what I need it to do, it certainly out performed what I thought! My wife was even making comments about the trail ahead and how it looked to be too much, but the LC didn't even hesitate or bog down at all!! She had fun, but did get a bit tired of all the bouncing around after awhile. But my 4 boys LOVED it and kept saying "MORE!". I think we will be going back.
So, my plan of attack looks like this:
1) SUSPENSION!!! I need to do something here. I am thinking either OME low-lift with larger tires, or the 2 in lift with larger tires. Since I have to do it anyway, I am probably going to go 2 in. But I need to figure out what do to about the load. Not sure I want to go all the way to J springs as they seem to make the thing set WAY up in the rear with no load. And since this will be a DD 80-90% of the time, that might be too much. Decisions, decisions......
2) Gotta move the spare tire. At least raise it up a bit. Might think about the Yakima rack. But I need to get some others feedback on this one.
3) Tow hitch has gotta go. Creates too much of a rear drag problem. Saw a cool double swing rear bumper with a hitch built in at Man-A-Fre that seemed like a good option. Anyone have any experience with this one?
4) Tires. Although the Michelin 275/70-16s did fine, a little larger would help with clearance (some) and a little more agressive tire would help in other areas too. Just not sure how big. 285 or 305? I think 33" size is proabably big enough for me. Don't want to completely kill the already bad gas mileage.
5) Interior protection. Even though leather cleans up fine, it would be nice to have some sort of slip covers that could just be thrown in the wash when done. Anything to minimize the clean up time when done. I have a Husky fitted mat in the back, and fairly generic ones in the front. I might get the fitted ones for the front and middle so that they are easier to clean as well. With the kids and dog, MUCH tracking of stuff. Not a problem as that is part of the fun, until you have to clean the DD to go to work. Anybody have any input on seat covers, etc.? Or am I being too anal here? :rolleyes:
6) Brakes. Need something here. I think the rotors are original, so they will be replaced. And 100 series pads in the front. Just need to figure out the rotor type (stock, drilled, slotted, drilled and slotted).
7) Tie rod ends. Also original, I think. But for $100 or so, better to know than to wonder and find out the hard way.
8) Birfields. Not sure of the condition. I just changed the oil in the front diff to synthetic and it was a bit dark. Also put in some more grease in birfields, but it wasn't "soupy" as I would have expected. Probably need to replace them, but not in a rush on this one. I will try to plan it so it makes sense with other changes.
Anything else anyone would suggest? Anyone volunteering to come over and help me install all of this stuff??? :D
Final thought: Passed a guy in a Jeep Wrangler (or the like) that was lifted and had Interco 35" tires. Not sure exactly which ones, but WOW! They looked like they could handle just about anything. He said they were kind of soft so it kept noise down. But I would suspect that would cut tread life as well. I guess that is why you have two sets of tires and rims... :doh:
Nice writeup ! Glad you had a great time .. and took the whole family along .
As for the height comment ... I take it your 4 boys had little difficulty getting in ? But regardless of their age and heights , tell your wife that my G/F Eron is just under 5 feet , and has never had any problems getting in or out of my 80 , which probably has roughly 3" of lift and sits atop 35" BFG MT's .
Good luck with all the plans :cheers:
Tyler
Thanks! Made a couple of additions above as I forgot a couple of things.
As for your 80, how good/bad is your gas mileage with 35s? Or do you have 2 sets of tires for on road and then for off road?
Rock on!! Congrats on getting out with the family...instill those quality outdoor values in kids and they'll love you for it! :)
As for the Cruiser, you hit on every item that all of us have found-out over the years. In stock form the 80-series is great, but suffers from a few things, the really low ass-end is one big one for Colorado since there alot of sharp climbs, you can't even get onto them, since the butt keeps dragging.
Regarding removing the trailer hitch, if you aren't going to use it to tow anything then yeah yank that thing off, if not, then dragging the hitch through rocks is better than even the frame. My first year at Moab I left my hitch on, specifically to hit things I would rather have a beefy hitch hit than anything else. In the end the hitch was ground over numerous rocks, couldn't even tell, didn't hurt it at all, I caught one rock on my plastic rear bumber-ettes and ripped them clean off...so my idea of the trailer hitch saving me was somewhat ill-advised.
I have 315x75 Goodyear MTRs on mine, which are by all accounts a 35" tire, gas mileage is mediocore, usually 12-13, I have gotten as good as 15 all with city driving, our highways here are mountains, so I don't usually get any better mileage there, worse if anything, but I drive it fast, passing everyone I can... :)
Congrats on getting out and playing with the Toy...oh all that power (grunt) you have with the engine, well with larger tires and altitude ALOT of that goes away...still a great vehicle!
About your wife and climbing in, my wife is 5'2", and pulls herself in like a champ, she even puts our son in his carseat, has to set him on the seat first, but for her to even lift him up (~38 lbs) to the seat is impressive! :)
Good Luck...
Mark Brodis
Very complete analysis. I'll comment where I can:
1.) The Kaymar/Tradesman full-length oval tube rack (sold by Man-A-Fre) is $495. Cheaper than the Yakima stuff, and much stronger and more versatile. Plus, you can sleep up there, put some lawn chairs up there for a view, etc. Only drawback (or advantage, depending on how you look at it) is the one-piece welded construction. You don't assemble it (IMHO making it stronger than most racks out there), but that makes shipping a bear, unless you live in Southern California and can pick it up in person.
2.) Get a replacement rear bumper with tire carrier. This also solves or helps solve #'s 3, 4, and 5.
4.) Get an aftermarket suspension. Plenty of info to help you make your choice on the Web.
6.) Get some 33" tires, in an AT tread. Come to think of it, I have some for sale...
8.) What kind of squeaks? For the most part, I wouldn't worry.
9.) Compromise with the boss is always a fine line...
11.) Don't bother. Stick with OEM pads and rotors.
I've got J springs with 285's and yakima rack too, and I get 11-14 mpg. Not good.
If you've got 4 kids chances are they aren't going to decrease in weight... I would go the J springs. With the Mr. Gasket 1" spacer in the front it sits almost level. Through the mutt and the kids and our junk in the back and it sits real level. I switched to these springs after running the 2" springs and I would not buy those again unless I didn't plan on using it off-road. That's why they are on my mom-in-law's LX now. She loves it and has no problems getting in and out. She's 5'2".
If you think it's top heavy w/o the tire on the roof don't try it with. Definitely do a different rear bumper w/ a tire carrier. Have it carry some jerry cans too for the crappy gas mileage.
Just get the heavy duty tie rod kit from Slee. My TRE's were frozen in place.
Do NOT buy Newfields! If you think you need to replace yours carry the old birf's as spares.
If your Michelins are in good shape then pic up a set of swampers on different rims; 13/33r16 or 13/36r16 will fit with bump stop modifications. Swampers are a serious tire. I feel naked w/o 'em.
Welcome to wheelin'! The kids will love it. It's a great family hobby.
The tow hooks and hitch serve to protect the rear of the rig. I've dragged the rig on the tow hooks (and bumper) many times.
The tow hooks and hitch serve to protect the rear of the rig. I would leave them in place.
Leave the tow hitch. I'm stock in my 91' and I've landed on that thing so many times. I'd rather land on that than the rear bumper. Once you get an OME lift with 35's you won't bottom out. My friend runs the OME medium load lift with 35'' pro comp X Terrains and he doesn't have the scraping problem at all. I need a lift :flipoff2:
I wouldn't consider the Js let alone with 1" spacers added. With what my truck has in added weight, I have the heavy duty fronts with a spacer and it sits just right. Some people have that higher is better approach. While it's true, it's only true to a point! My first OEM was the medium setup. Had slight rubbing with 35" tires. Then went to the heavy springs and the rubbing was gone. Then added the front ARB and wanted a little compensation for the added weight so I added the spacers. Been driving the truck for quite a while and this progressive approach has worked out well. If I was to get a winch then some stiffer springs and phantom caster plates from Slee are in order.
Tank has a point. If you aren't comfy with a taller rig. I wish mine was higher still. :D
I am still trying to get used to about 15" less clearance at the rockers than I was used to on my 40.
If you are interested here are the measurements that I have taken with different spring setups on my two rigs.
Front measurement taken at bottom of driver's side frame horn.
Rear measurements taken on bottom most portion (center) of receiver tube.
All measurements are in inches.
Okay these are the #'s;
'97 LX450
Stock: Front/Rear 17.25/12
OME 851/863: Front/Rear 19.25/15.5
'93 FZJ80
OME 851/863 Front/Rear 20/16.5
OME "J" Front /Rear 21.75(21.25 w/winch)/18.5
w/Mr.Gasket 1" spacers in front only:
Front/Rear 22/18
The Lexus I believe sits a little lower than the factory '93 FZJ80, the springs are definitely softer on the LX450. The '93 is fitted w/ an ARB bar with an 8274. All measurements were taken with third row seats in place.
Have fun! :D
Butch
I'll bet the squeaks are from the front shocks needing a little tighteming. The bushings will squeak when they are even a little loose.
Cheers,
Sean
SP
>> 1) Anybody had any bad experiences with Yakima stuff? <<
>> Probably not as rugged as the ARB or Safari stuff, but at less than half the cost...... <<
Yep, it's not as rugged as the good stuff.
>> 2) Could mount it in the Yakima MegaWarrior basket (has anyone done this?).
Not recommended for a lot of reasons. Mainly getting a 100# 33" tyre up and down is a PITA, plus that's all you'll carry up there, plus more things hit the tyre up there, plus another big change in the COG.
>> 3) Factory tow bracket is way TOO low. <<
That's OK. Draggin it is not going to hurt it but dragging your rear bumper will. Remove it after you get a proper Slee or Kaymar or Hanna rear bumper.
Correct. We've been recommending an OME to you.
See 4.
Get some decent off-road tyres. A/T's if you must... MT's if you can.
It's just a matter of time. Get some decent sliders; Slee or Hanna. Get a small step stool for her if she complains. The sliders can be used as a high step.
Use low gear for engine braking and stay with OEM rotors as long as they're in good condition. To improve brake performance use 100 series front pads, flush with Syn brake fluid and install SS brake lines.
The OME will help.
> 1) SUSPENSION!!! Not sure I want to go all the way to J springs
Go with the OME medium or heavy depending on static loading. Call the guys at Slee Off-road and they'll set you up correctly.
Raise it until you can afford a proper rear tyre carrier.
Not recommended.
>> 4) Tires.
Get some 305/70R16 BFG A/T's or GY MTR's.
Great Covers. There are several posts; at least one current. Search.
>> 6) Brakes.
See above.
>> 8) Birfields.
You need to do a front axle service and assess the condition of your stock birfields. Since they are expensive it seems a waste of money to replace yours unless you know they are not serviceable. If you must replace them, use OEM.
Maybe. Where do you live and what kind of beer do you serve?
-B-
My thoughts on the Yakima MegaWarrior...
Pro: less expensive than the ARB, Safari, or Hannibal.
Con: not as rugged/strong as the ARB, Safari or Hannibal, Tradesman, etc.
Pro: because it's modular, you can expand it (they sell an extension).
Con: to really use the extension, you need at least one more bar. I'd suggest 1 extra bar per extension. On the 80, the MegaWarrior + 1 extension is about 3/4 roof rack size (it stops right at the sunroof).
Con: they don't provide an additional bracket to hold the extension to the extra bar -- you have to buy another pair of mounts (if you want to secure the extension.
Pro: if you decide to sell it later, you have a fairly large market to sell to -- the Yakima will fit most other full size rigs (and it will fit on their factory rack -- which is a selling point for most consumers).
Pro: it's easy to install/remove. for me it's a one-man job. the rack is fairly light.
I got mine so I could haul all the additional luggage required to take the wife and kids to Moab. I was in a hurry (they couldn't guarantee delivery of a Garvin Wilderness Rack on time and I didn't have time to drive 5 hours to L.A. to pick up a Tradesman rack), so I got mine. I've used it twice (once in Moab and just this past weekend); it's okay -- gets the job done, but it's not what I REALLY wanted.
If you need to haul al lot of different things; i.e. gear for trips, kayaks/canoes, bikes, skis/snowbards, etc. I think the Yakima system works well -- with it being modular, it's easy to swap parts in and out. If you're planning on using the rack for just hauling gear and you want the kewl factor with the other cruisers -- get one of the other racks.
Thanks to all for the input.
As I mentioned, it was a lot of fun, with no mishaps (guess I wasn't trying hard enough!!!).
I will be calling Slee this morning. Suspension, brakes and TRE will be first. Tires as soon as I can find a buyer for the ones I have on there now (Michelin LTX 275/70-16 with about 90%+ tread). Spare tire lift as well, once I re-read the post on how to do it and go get the appropriate bolts.
Now, to plan the next trip..................... :D
stress puppy good call on calling christo. he may not be the cheapest source for ome equipment but the service there is worth the $$. also you can talk to them about racks. having seen the outback line he sell in person I was very impressed. Do not throw your tire on top look for a post showing how to raise the spare or throw it in the back of the cab.
I disagree with everyone on just one point I lost my factory hitch and am not sad about it. I have an arb frnt and use the tow hooks on the frame rail ends. If I hear them scrape I know I am close. as far as the bumprettes on the ends... I am hoping they get destroyed as I need some motivation to finish the design phase of my rear bumper.
One last point on the height of the truck, my wife is 5'2" and I have the 2" and 33" tires. she can still get in and out without any steps. thats why they yave two handles on the front seat.
Dave
Called Christo. What a great guy!! Ben too!!
Anyway, 851/860 with shocks, damper and caster correction bushings on the way!!! That's a start. But I am sure that once that is on, the small tires will look funny and NEED to be replaced soon there after.
And the best part, when I told my wife I ordered it, she said "I figured you would after the scraping and such we did this weekend........" :eek: I need to take her wheelin' again so I can find more ways to justify upgrades!!!! :bounce:
fidn some mud and the need for better tires will be apparent.
Dave
