finally starting the new 2fe, snag
Alaska
well I finally quit procrastinating and got the 2fe all hooked and lubed up. Tried to start er and no go. :crybaby:cranks fine but i'm getting no fuel pressure. Yes I have the FSM. I'm a total stranger to EFI systems. :confused:Do I need to bleed the fuel sytem? Is there a dedicated fuel pump fuse? The rigs been sittin for about 2yrs could the fuel pump have froze up? Any possible suggestions would be awesome. I'm looking for a quick and instant fix of course:D. Otherwise I guess i'll have to do it the old fashioned way and just start eliminating the possibilities.
:cheers: Adam
the fuel pump relay is in the side kick panel on the pass side.
also maybe the connector in the left rear wheelwell area could be bad, that's what happened to mine.
you can run a wire straight to the connections in the cargo area (move carpet) to see if the pump actualy runs.
DOH!! I'm such a moron! When I did my quarter chop I had to disconnect the fiel pump connector that goes thru the ds rear wheel well. Fired right up when I figured it out:o
