We are far from the salt belt states levels of salt on roads, but still not as free as it used to be.Good to know about the salt
I wrote up fixing the same issue on mine.After my 2013 LC was in an accident and the front bumper was replaced, I also had a leak at the headlamp washer. IIRC, the body shop fixed it by lubricating the tube that connected to the washer. I believe they said that they just lubricated an o-ring.
I did that on my 2013 LC. I haven’t yet done that on my 2020 LX, but I’m considering it.And ditch the locking lugs once you get them off.. not worth the risk of breaking the key on the side of the road in the middle of nowhere. Stock standard lugs are part number 90942-01103 but prohibitively expensive.. I'd try to find used ones somewhere.
As a recap, the differentials have a breather to relieve pressure when they get hot. The breather end is normally fitted with a loose end cap and terminates high enough to avoid water getting in. If the breather pipe/hose is disconnected, especially down low, it’s possible (but fairly unlikely) for dirt/water to enter the diff. I’m unclear about exactly what’s going on with yours, but given the vehicle history, I suspect the oil is fine. Just make sure sometime the breather is connected and somewhere close to the right location.I have not actually traced the metal pipe above the axle to the diff, but assuming that is the breather pipe, then it disconnected from the the other “extension hose” as I’ll call it. So that extension hose that goes near the wheel well behind the plastic cover but is not actually connected to the breather pipe so it’s essentially doing doing.
I can certainly connect it if it’s ideal, but the diff fluid was changed about 23k mi / 3 years ago if it makes any difference. If you think it’s still needed I can get that done or do it myself if it’s not too hard.
Gotcha. So yeah it is definitely disconnected from the other piece that terminates with the metal cap. It’s something i can reconnected so I will do that since it is just a bare metal pipe with no “protection” from the metal cap right now. At least it is relatively high up though. Above the axle and hidden away in a little nook I can barely even get my hand into. That whole area looks really clean so I’m thinking not much road debris and dirt gets up there.As a recap, the differentials have a breather to relieve pressure when they get hot. The breather end is normally fitted with a loose end cap and terminates high enough to avoid water getting in. If the breather pipe/hose is disconnected, especially down low, it’s possible (but fairly unlikely) for dirt/water to enter the diff. I’m unclear about exactly what’s going on with yours, but given the vehicle history, I suspect the oil is fine. Just make sure sometime the breather is connected and somewhere close to the right location.
You can remove the locking lug nut. Get sockets out and hammer on the one that will almost go over it. Hammer it on and remove locking lug. You will likely have to remove the socket on a bench by driving it out the opposite way with a hammer and some kind of punch. Repeat until all 4 are out. This may cost you your socket.
I’m leaning towards this to avoid the hassle with getting a replacement key and then always needing to have it on hand. Any issue with using aftermarket lugs? Doesn’t bother me that something isn’t OEM as long as it’s good quality. I agree those OEM ones seem unnecessarily expensive.And ditch the locking lugs once you get them off.. not worth the risk of breaking the key on the side of the road in the middle of nowhere. Stock standard lugs are part number 90942-01103 but prohibitively expensive.. I'd try to find used ones somewhere.
Anything against doing a “reboot” or whatever the proper term is? Looks like part 04427-60090 is a kit to do that for $50. I guess the only issue is that if during the process it looks like the CV joint is actually damaged then I’m screwed and have to wait around for a new axle anyways. I don’t hear any weird noises so what are the chances the joint is damaged.Absolutely do not run aftermarket CVs. Total trash.
Would help if I attached pictures.Anything against doing a “reboot” or whatever the proper term is? Looks like part 04427-60090 is a kit to do that for $50. I guess the only issue is that if during the process it looks like the CV joint is actually damaged then I’m screwed and have to wait around for a new axle anyways. I don’t hear any weird noises so what are the chances the joint is damaged.
Otherwise if I just get a new axle. Is this the correct one? Are they the same part for either front driver/passenger side.
One website for “Lexus” parts shows it as being compatible with either side even though it says “LH”
And then a “Toyota” part site specifies front driver side only. Also for $15 less.
If my assumption is correct, considering it’s all literally the same part at the end of the day. The Toyota one is fine and is in fact compatible with both sides.
That makes sense. I’ll go that route and just start fresh with a new axle and not have to worry about it down the road.The parts diagrams show the same part number for both LH and RH, 43430-60071 , But a quirk in the system is that it still has LH and RH on different lines in the listing. So what you are seeing is just a reflection of that.
And yes the toyota and lexus parts are the same.
The problem with rebooting your existing part is you don't know how low it was run on grease, or how long, even before the reboot. Then whoever did the existing reboot job didn't get the clamp right, so what else didn't they do?
IMO with a new to you rig that is so clean, just spring for the CV and start fresh, as you noted they aren't that expensive. Will you do the work or pay someone? Getting the CV out means disassembling the front hub, and just one detail there is a special tool is needed to properly torque the bearing to knuckle bolts.
See this post:That makes sense. I’ll go that route and just start fresh with a new axle and not have to worry about it down the road.
I was planning to do it myself, honestly I only skimmed through a couple videos on YouTube (may have been for a 100 series tbh), but then found the official repair document in the factory service manual and skimmed through that also, at a glance it didn’t seem too bad but I did not catch the part about needing a special tool. Do you by chance know what tool that is? I was under the impression I may just need a couple uncommon sized sockets.
