I;m installing a Downey aluminum rad in my 40. I read somewhere on MUD that a 7-8 blade fan from a big block chev would be the best fan to use to assist in the cooling. I bought one at a wrecking yard that has a clutch on it. What is the benefit of a clutch and how to I test it to see if it's functioning properly. Also do I still need a shroud with this large fan?
I've done a search and am still not clear as to where the fan should be placed in the shroud. Not in the shroud at all, only a little inside the shroud????which will give the best results.
Thanks, Greg
Thanks, Greg
