So as many of you know I have had a problem with water temps in the summers when it is very hot outside like today 106deg. I recently got a scangauge II and thought I would finally try and get to the bottom of this problem.
Things we have tried.
Changed the rad. to brass unit
changed the thermostat
changed coolant flushed twice
changed fan hub to blue unit
changed fluid in the blue hub twice to thicker fluid
Made foam and shroud were in correct places around radiator
Info from today
outside temp 106-110
intake charge 128-138 while driving
intake charge 145-155 while in drive through at In and Out
water temp on freeway 191-195
water temp at stop lights 198-202
water temp at InO 198-211
at rest with foot on brake RPM's are just under 700
in park they rise to just under 900
If I put it in park and rev to 1500-2000rpm the temp goes back down to 195-198 in a min or two
So I have come up with a couple of things....It is safe to assume that I am not getting enough airflow through the rad during stops! Is my idel set too low? Do I just need to hook up the pusher fan I already have? Do I need a new water pump? (I doubt) Do I need even thicker fluid in the fan clutch? Do I scrap the truck and try again with another truck??
Do I keep doing the same thing and leave my truck in the garage for the summer months??
I am also cross posting this in the fan clutch thread.
Info from today
