- Thread starter
- #21
We have done mine twice...once at your shop early on and then once at truckworks at he CSC club work day. I don't remember which fluid but I remember you put thicker than you had put in others. At that time you checked over the ac condenser and rad and didn't think it was bug littered I have kept that pretty clean. I'm not sure about the air flow around the tires...I will check.
i have never replaced the dryer...
I will get a new cap this week, I checked around the injectors and exhaust manifold and didn't see any gas etc. I have gotten a code for o2 sensors bad, however, it hasn't come back since cleared. I might replace them, I think I might have some small exhaust leaks around that area from my truckworks exhaust so that might be throwing the codes as well.
If my temps seem normal than maybe it's just poor ac performance. Like I said I haven't had it boil over or shut off the ac completely since the last time we changed the fluid in the fan clutch. I figured it would do the same thing because it kept going up and I intervened at 212 but since that time I can get the temp up that hi...I will keep working on it
But as the temp goes above 202 the ac gets warmer and warmer till its not cold at all. While I was sitting in the truck reading and watching the temp gauge yesterday I had the ac on full and was sweeting with the temp gauge at 206-207 so the ac was pretty ineffective at those temps....so if those are normal temps then my ac has problems...not my cooling system
am I making any sense??
