Fairey Rebuild, new shift fork and synchros.
surf coast, Australia
Hi All, almost finished my Fairey OD rebuild thread so I thought I would share my progress.
I bought a later model split case Fairey early last year for my HJ47 that ended up having a busted shift fork, which was unfortunate as I was hoping to just put it all in without any extra work. Good thing I checked as the synchros were absolutely shagged too. And I can put in the longer shaft for the transmission style handbrake.
It seems that these are the two major problems with these units (fork, synchros), apart from that they should technically be stronger than a H55, more teeth surface area and bigger bearings...and hopefully more fun!
The shift fork is a piece of sh**, a single piece of cast bronze that is too slim for the job and with tight radius curves that create stresses where they all seem to break. The wear pattern also indicated that the fork didn't actually grab the hub properly but sat too far away and only grabbed it on one side of the equator which could lead to binding and breakage as someone pushes hard on the shifter to rectify it's stickiness. The piece that came off got crunched up too.
I decided it would be best to replace it, I did some careful measuring and some simple drawings on CAD which I can share if someone wants. The main piece was roughed out using a band saw from a piece of aluminium plate and some bronze pads were machined for the sliding surfaces, these are screwed on. The aluminium was machined parallel/perp relative the bolt hole side and the pad mounts. Some guys at work were kind enough to do this for me.
In place,
As I said before the synchros were badly worn, I thought that this could of been the end if I couldn't get some new ones. I knew that a company like Fairey would of just used some other off the shelf parts of the time. With a bit of luck and a google image search I found the synchros to be from an LT77 Land Rover/Triumph gearbox (part no: FRC8232). They were only 7 pounds each from the UK haha.
Above pic is from ebay, below is the old one
I have also replaced the bearings in my H42 and the output shaft bearing and idleshaft bearings in the transfer case and all seals, just waiting on some locktab washers and put on the overdrive counter gear plate and handbrake, hopefully it works after all this effort haha.
Mostly, finished product
Good write-up, and good fix on the fork. I am surprised tho. In all the Faireys I've worked on over the years here in the States, I have never seen one with a damaged fork. Their tolerances still leave a lot to be desired. :rolleyes:
Best
Mark A
I'm not that experienced with them, I was basing my judgements about the fork on forum posts and the ones I've seen for sale in Aus with a busted fork. It's all in now, just need to fix all the other things on the car before I can give it a proper test.
Somehow I missed this thread. If the shift fork is the same as the earlier bolt on style I believe I have a few spares. Hardest part for me on the early case is the four studs that bolt to overdrive to the back of transfer case. I believe the thread on transfer case is 8MM and the overdrive is only 6MM. I have enough to do one more overdrive. The plan is to make a poor man's H55F. Have a H41 with a worn tailshaft. The splines on the overdrive run is a different location.
John, the studs are 10mm on t-case side, 8mm on the o.d.
Hi @Living in the Past,
I know this post is from 2015 but if you still have a spare fork I would be interested in buying one. I own a
1984 HJ47 Landcruiser with a 4 speed fairey overdrive. Cheers Jake
Should still have the shift fork. I do not know if Fairey used same one for the one piece transfer case and the split transfer case. The OD are at another location. Will be around first week of next month.
Hi @Living in the Past.
My fairey is the split transfer case. Where are you located and how much would the fork be if it fitted mine please. Cheers Jake47
I'm in AZ USA. Are you in NH? Or is Londonderry in Australia? I see one in WA and NSW. By the time of your first post guessing Australia. Here is the type of Fairey OD I have and most but not all the parts are.
Most these were sold years ago. When I'm at the location all my OD parts stored will see what I have and measure the fork then we'll go from there.
I know the H55F and split transfer case with the hand brake is a very tight fit in a 8/80+ 40 series. Did the Fairey OD have any clearance problem.
@Jake 47 was able to find one shift collar, it does show signs it was installed but definitely serviceable.
This is from the pre 8/80 OD that fits the one piece transfer case.
In place,
I know it's been a few years since this thread was active but you wouldn't happen to have the drawing to the shift fork still? I just purchased a fairey overdrive attached to a H55F and it is missing the shift fork.
I got your PM, I do not have a split transfer case shift fork. My collect was all for the one piece transfer case except a few heavy ball bearings not sure if they were from the later Fairey OD that fits the split transfer case.
