Faint pop sound underneath my feet when turning right only???
cc93cruiser
CRUZAHEAD
Hayward, Ca.
Whenever I turn right while driving my 80, I almost always hear a very faint pop sound coming from around where my feet are.. The pop almost sounds like it is due to a very slight frame flex or some front suspension component..If I remember correctly, it started to do this when I put on my father's donor J springs.. I am sure it is not a problem, I am just curious as to what is making the sound and it is annoying me.... You can only hear it when you have the radio off, it is that low of a pop....What do you guys think?
it can be one of the body bushings right by your foot and the through bolt is a bit loose, loosen the bolt all the way, then re-tighten, it fixed my mystery pop, it has that "I wonder if that's my birfield" sensation, so it is nice to get rid of the sound for good.
I just did my front axle service about a month ago, so it is not that... i will definitley look into the bushings...Thanks....
Those are curbs. Turn less sharply.
