External Molle Panels with Dissent Roof Rack (8 Viewers)
California
I just ordered a roof rack from Dissent. Anyone have one and use external molle panels on the rear windows. I am trying to figure out what ones are compatible with the Dissent roof rack. All I can find are Prospeed, which have two versions and Ohana Rig supply has a version. Not sure if any of those are compatible. Any other known options that will work?
Contact Ben the owner at Dissent. He had that kind of setup on his orange 200 Series. I’m sure he has the files saved and can make you something similar. @benc
Here
Have you asked Prospeed? You may not be the first person to try this. Looking at the mounting system, it looks like it has some adjustability both up/down and left/right.
I was leaning towards the prospeed. Not a bad idea. I'll give them a shout tomorrow. Thanks!
Can you post side picture of your roof rack? I have ProSpeed exterior panels and can see if they would mount on Dissent roof rack.
I have asked Dissent for this for a few years, but I don't think they will bring it to mass market.
From what I have seen of the other vendors is that they would need to make a custom plate for the Dissent rack. The mounts I have seen only work with the OEM rack or the flat vertical rack like the ProSpeed.
I'd be interested in a set if you need some quantity to get them made. Been wanting some for a while and was always hoping Dissent would finally release them.
I would be down for the adapter. I have a set of external molle panel waiting to be mounted.
Because of my constant pestering, it looks like Dissent may make their own. I have already committed to my vendor, so I wont be using theirs unless my guy falls through
Would possibly be interested as well, I always wondered why Dissent did not offer this in their lineup. I am curious though with the vendor you are going with, will there be enough space between the back window and side panel to where the side window is still operational or will that be something that will need to be given up to run them
Not sure on this version. I did see a version of Molle that allows you to use your rear windows, but I cant remember who it was since I was probably doom scrolling at the time. The issue with the Dissent rack is the slight fold in the middle of the side slats that run the length of the room. Sherpa, Prinsu etc or flat to easy to attach to. This one has a bend, so my guy is figuring that in.
I emailed and called Prospeed, no response. Ohana Rig supply was very responsive and Nick even called me about it. Other than those two vendors, I'm not sure who makes external molle panels for the 100 series.
Shouldn't be too difficult with the bend, I bet if you find someone who has the awning mounts they could follow that bend or use that as a nice start for an adapter plate
