Exploded Winch!
Magnolia, TX
I was given this Ramsey RE8000 winch the other day. It was hooked to a winch truck and the truck rolled backwards (no one was in it) against a wall which caused the remote to be activated which started spooling the winch up. The winch bound up so tight it caused it to explode. :doh: Does anyone know if this winch can be salvaged. If it costs a few hundred bucks to get fixed, then I'll send it in and have it done. If it is going to cost something close to the price of a new winch then I'll trash it.
So what do you think?
My un-educated guess is "not repairable" due to it being the cast metal housing that blew up.
this site makes it sound like repairs happen to moving parts: http://www.ramsey.com/rrp.html, but it does give you a # to call.
Since a new one will set you back a grand its worth a call tho, eh?
Good luck!
That is a pretty major failure. I would call for sure and ask for a replacement and see what they say.
Good luck.
Rezarf <><
Pretty sure I've got a used case for that winch sitting out in my graveyard. I'll check on Monday. Drop me a line.
Mark...
Mark...
If you do let me know, that would be great.
wow, that's a pretty thick casting. Must have taken a serious hit.
Something you could try if no replacement casting is available, would be to weld it with a rod specific to cast. They are available and if the proper procedure is followed, a reasonable repair can occur. Try taking it around to some welding/machine shops and see what they have to say. Might be worth a try if the price is right.
a little J-B weld will fix that right up
You could be right. The timing chain on our Saab broke :crybaby: and the dealer glued a break in the cover(casting) with some sort of super epoxy and it's been fine. Saved us $900.00
