Been driving from Denver to Flagstaff the last couple of days pulling my Sea Pearl Trimaran (1500lbs) with the 80. I've noticed some things about the transmission and I wonder if someone can give me a little tutorial on how it functions. If I'm in overdrive and it downshifts going up a grade, I assumed it was downshifting into third. However, if, once it has downshifted, I turn off the overdrive, the rpm's will drop 200. Also when in overdrive, if it shifts back up from third (?) to overdrive, the rpm's will momentarily stop at X and then a second later, drop down another 200 rpms. So it looks to me as if when in overdrive and downshifting automatically, it unlocks the torque converter. Is that correct? So, when I turn off the overdrive when it has downshifted, it re-engages the convertor lock up hence the 200 rpm drop. It also re-engages the lock up in overdrive once it upshifts again.
Knowing this fact is important because if the 4 spd Allison in my Bluebird Wanderlodge is any indication, an unlocked torque convertor produces a lot more heat. So, when doing a lot of climbing, disengaging the overdrive and allowing the transmission to lock up which it appears to do in all gears when the overdrive is off will keep things cooler.
Can anyone shed light on this interpretation of transmission behavior?
