Dusty said:sorry I inadvertadly removed my pics by mistake. It was an earls oil cooler 6"x9"
scott I put a mocal oil thermostat on it. I agree that there are better ways to cool this motor from my experementing
When I first jumped into this forum, I was pretty convinced early on that the problem with 80's cooling was due to oil. Since february of this year, I've become pretty convinced that the problems with 80's cooling is two fold. They run cool too much of the time, and they run really hot when they get hot. Oil temps don't appear to be a problem until radiator temps are. Luckily this appears to be a more simple (though maybe not so simply discussed here) concept of heat management.
That transmission cooling circuit really adds a monster heat soak to the condenser, radiator and engine bay. I'm pretty convinced that following/including hood vents the main culprit to overheat engine temp problems are in that trans circuit. I'm also quite hopefull that the hardware toyota delivered is good and efficient (aux trans cooler) but just needs to be relocated.
Doing something about the in tank cooler might prove a bit more challenging.
Scott Justusson
