Hello all, in need of a little assistance please.
Have a 4.5 petrol whose engine recently started missing a beat. Firstly the vehicle is well serviced and low mileage.
The symptons are; drives fine under light throttle / flat roads. Under a little more than gentle throttles or medium / steep hills the engine starts to miss a beat. At first I thought a plug lead(s) had come loose as under light loads they would not be evident but under heavier ones they would.
As this coincided with a service I asked the garage to change the plug leads / distributor cap at the same time as the car is 11 years old. Sadly this did not work.
Now heres a puzzling part of the jigsaw. For the first 5-10 minutes after starting in the morning the engine runs fine. This is not just when its cold but as the engine warms up quickly, also when its warm.
On this basis I wondered if it was a sensor gone down.
Have tried redex and this did not work. The problem is so bad that when I recently went up a steep hill (1 in 4) I had to put it in low range first to get up and then it struggled.
Help please....
Help please....
